Insane Network Engineer
Get in truck, close doors.... Jumper pins 4 and 8 on the ALDL. The doors should lock when you jumper them. On your oem remote, press and hold both the door and unlock buttons at the same time until the doors unlock. Your remote is now programmed... Remove jumpers.
Banned
meh.....
I suppose you can read? Theres the search button up there. ;) Thats how I found out to program mine.
But......since I'm feeling kind of nice tonite......
Get in and close all doors.
Insert key.
Press and hold door unlock switch.
While holding unlock, cycle key ON, OFF, ON, OFF.
Release unlock. Door should lock and unlock to confirm "program" mode.
Press and hold LOCK button and UNLOCK button for 15secs on the keypad. Door should unlock and lock to confirm programming.
If more than one keypad is needing programming, do last step as many times as needed as there are keypads.
Turn key to RUN position to exit the programming mode.
blacksls00 said:
meh.....
yeah i can read,lol thanks tho, i appreciate it!
Banned
rlith said:
Interesting... I wonder if they changed the procedure for the later models (2000-current) I know for a fact 99 and below work with my method...
:dunno: Maybe both will work?
Just making sure Twins. ;)
No prob. :rock:
