How do you get rid of DRL on 98 and up s-10's?
maybe it's the 4X4 or something but mine will cut off if i hit the button a few times and the e-brake thing doesn't work for mine.....like jeffyboy said...there is a way of getin rid of them by bending two prongs that are on the fuse so they aren't functional.....i can't remember which two they are but if i find out i'll let ya know2001_S-10_4x4 said:if you have a `98, you cannot just push the dome override button four times to shut the DRLs off. Trust me on this one, I drove a `98 for 3 years and the only way to shut them off was either to monkey around under the hood looking for the relay, or simply push the emergency brake pedal down til it clicks once....this way the e-brake light will show up on the dash, but it won't be doing anything and your DRLs will be off.......
That is a temporary and non-technical way to go about it but I know there are more permanent solutions too!
Good Luck!
isn't there an additional diagram with that, where you can wire fogs up for 6 way highs???sweetbutxtreme said:here is the wiring diagram if ya wanna do the low beam/high beam mod
