I just had my frame plasma'd and the guy took out my fingers inside the spring cup. My question is how does the top of the bag cup mount? do I need the frame up there? and or the fingers? ( I may be stuck with my shockwaves!!)
those fingers are there to hold the spring centered in place. as long as you use jasons cups, or some bolt in cup that mounts through the upper shock hole you should be fine.
Why did he cut those out??? what all did he replace? I need to check this out sometime....
He cut it out so from the shock mount plate to the lower A arm I have a 8" diameter by 11" tall hole for my bags The top of the frame is all gone, so will jasons cups still work? also He Hand formed and welded in a 1/4" by 3" steel plate to make a new spring pocket. I now have about 1.5" of space between the shockwave bag and the frame!! I will draw up a pic to show you.
