thank you. Where can I find the machined pad with stampings? Thanks.You have casting numbers there, not the machined pad with stampings, of course. I ran into this post, below, has the block numbers you showed above. Might help.
block cast #
Hey Hey whats up i am working on a 93 gmc sonoma i have a 2.8 ok i called the parts store. to find out if this motor this guy has will work i am looking for a replacement motor for the 2.8 the 93 has a block cast #695 and 89-92 have block cast numbers 457 and 695 i am wanting to know i i have to...www.s10forum.com
those rockers are on a head that lives under my workbench. it is from the original engine. I just wanted to see what the date code said it was on a known date head. what does CW mean?I think you’re overthinking it. Small crank, large crank, who cares? It’ll last if taken care of.
You have all the belts, so you have a CW water pump.
Flywheel can be resurfaced if you’re replacing the clutch. Wait until you actually pull the transmission on that one.
I’d suggest to simply un-booger what you have. It shouldn’t be difficult. Compression test the motor first to see if it’s even worth your while.
Edit: why are your rockers every which way but proper?!?!??!
Sent from my iPhone using Tapatalk
Generally, CW is the opposite of CCW (CCW = counter clock wise, CW = clock wise). And, if you keep accumulating casting numbers, you may need to start an Excel spread sheet to keep track of all of them.................. what does CW mean?
what is the name of this book? its really comprehensive!! I would like to get a hard copy if you know the title and author I would appreciate that thanks.See this old post, particularly Post #11
Here's PDF with similar, but more detailed info. See page 8 about cranks.![]()
60*V6 Parts swapping: What Fits and How.
So the forum ate my first thread on swapping parts and all the questions that get asked all the time here. I'll try again.www.s10forum.com
Hopefully you have an 88 up engine.
