On my 88 s10, I have a small leak on my drivers side rear drum cylinder that a mechanic pointed out to me a few years ago. he said it was not something to worry about but I should get it changed before it gets worse. He also said there was a slight leak in the rear axial seal on the same side and that is expensive to repair, he said the dirt from the fluid leaks in the rear drums might make the rear drum grab a bit not being as smooth so i might notice that when coming to a full stop and i do notice that. i do not use the truck as a daily driver, only occasionally like once a few months.
Also recently within last year I notice when braking my truck pulls slightly to the left, its not too bad. I think it happens more especially if it has been sitting parked and not driven for a few months . i was thinking of replaced the brake hoses.I have been working full-time and so I just didn't have time to address these issues.but I did buy some brake hoses for the front because I thought the pulling wad due to old hoses so the fluid is not reaching all the whelks at the same time.
I want to understand how the brakes are design. I see the s10 has two brake fluid reservoirs. I always thought that the design of the systems with two reservoirs was that if one leak happens brakes fail, say in the rear cylinder bursts, then the front brakes still work. I thought it was a rear front split.
but i think I remember someone said to me that is how the cars were designed in the 60s and early 70a but then they switched to making it that the brake fluids lines isolated diagonally so of that is the case, then if there is a leak in the rear drivers cylinder then there would be diminished braking in the front passenger brake and the rear if there was less pressure in that system.
Can someone please clarify how the brake system is designed? Is the pulling to the left from the hoses or a sign the cylinder is failing more? I never added brake fluid to the truck in years and now inspecting the fluid it looks clean and seems pretty full in both reservoirs, but the front reservoirs is about 1/4 inch lower than the rear reservoirs. i have all the tools to change a cylinder and hoses and think i can do that or have a friend do that. i just want to be safe.
Im about to head out on a moving trip with the truck loaded and pressured due to limited time. The small town I'm moving too has a great low cost mechanic. The truck seems to stop pretty good besides the pulling but i sense the petal feels good but the way the brakes grab is not totally smooth and the pulling makes me concerned.
Can the pulling be telling be the cylinder is about to blow?
thank you.
thank you.
