The body work is all okay. I was a little worried about the cab seams and that kind of stuff, but nothing happened. It's not like it's a daily driver or anything.
The bed is bodydropped 7". Seems like a lot, but there is a lot of stuff under there. My fuel cell, air tank, valves, battery, and compressor are all under there. I bded the bed last spring so I just need to redo the mounts to match it with the cab now. I was planning on an eventual bodydrop so I made sure i had a 3" gap between the bed floor and all the stuff under there.
Has anybody run into problems with the radiator fill cap being lower than the water neck on the motor? The hose to the puke tank is supposed to be at the highest point in the system to purge the air bubbles. I am thinking about welding the fill cap on the radiator shut and buying one of those water neck/fill things like a lot of race cars use.
Sorry for the long post, I should have some more pics up tonite. I am cutting the floor out right now.
