Thats the ones I was looking at then saw the Summit and was wondering what was the difference. They look allot alike.Save yourself the headache and get the Hooker cast manifolds. They fit well, and if you have them ceramic coated inside and out, they really cut down on the heat. That’s what I did. View attachment 346649
white box? Thats my other part I was going with the H3.They very well could be the same product. We went with the white box oil pan from Holley...only difference was the name cast on the bottom...it was considerably cheaper.
Kinda like the white cans of beer that only say BEER on them...“White box” not a name branded on it.
Summit also sells a set that in not specifically for an LS / S10 swap so be careful what you buy, make sure you get a set for the LS / S!0. I ordered a set from Holley at their Holleydays sale...they haven't shipped yet, they probably have a certain number cast at one time, good thing I wasn't in a hurry.This is for a 2002 blazer xtreme so I do have a little more room. I'm also buying mounts from Harley designed for the blazer. There does look to be a slight difference between the Hooker and the Summit. The Summit look more like the other cast header Hooker offers. Maybe someone on here has used the Summit ones. I really like the cast headers.
They ship from Texas....That is the major point. If the manifolds, or even headers, don't specifically say it's for an S10 LS swap, they won't work. The less expensive manifolds are for things like old C/K trucks or other wide vehicles. The S10 specific ones are tighter to the block to clear the narrow 2wd S10 frame. And naturally more expensive.
Summit has 8 pair of the Holley Blackheart S10 LS manifolds in stock and will ship today. Rather than waiting for them from Holley in CA. Whenever they get more from China. I'm sure all the container ships are full of face masks at the moment.
Hooker Headers 71223026HKR Hooker Blackheart Exhaust Manifolds | Summit Racing
Find Hooker Headers 71223026HKR Hooker Blackheart Exhaust Manifolds and get Free Shipping on Orders Over $99 at Summit Racing! Hooker Blackheart exhaust manifolds are designed to be used with Hooker Blackheart engine mounts and transmission crossmembers for a trouble-free installation. They...www.summitracing.com
Agreed no argument here I was just curious if anyone had tried the blackheart and their thoughts on the money spent. Also wanted to know if anyone has tried to fit the Summit headers on their build. So they are more expensive because? There are limited applications is my thinking. Engineering is engineering.That is the major point. If the manifolds, or even headers, don't specifically say it's for an S10 LS swap, they won't work. The less expensive manifolds are for things like old C/K trucks or other wide vehicles. The S10 specific ones are tighter to the block to clear the narrow 2wd S10 frame. And naturally more expensive.
I think they are worth the money. Headers usually fit. Might have to ding them up here or there, or do some carving on the UCA. As long as you don't mind crawling under it every so often to tighten the collector's up...nah....I'd go with the cast manifolds. Loose 10 lbs and your can probably make up the diff from any hp losses... 🤣Agreed no argument here I was just curious if anyone had tried the blackheart and their thoughts on the money spent. Also wanted to know if anyone has tried to fit the Summit headers on their build. So they are more expensive because? There are limited applications is my thinking. Engineering is engineering.
I'm with you less chance of leaks, not as hot and should hopefully fit without a dentI think they are worth the money. Headers usually fit. Might have to ding them up here or there, or do some carving on the UCA. As long as you don't mind crawling under it every so often to tighten the collector's up...nah....I'd go with theist manifolds. Loose 10 lbs and your can probably make up the diff from any hp losses... 🤣
That's what I thought I looked closer and you can see that they turn down where the Hooker stay up. Look at Rhotpursuit beautiful build that is what I'm talking about great work.I asked the same question a few months ago, s10dude said he bought the summit ones and they dump right onto the frame, they don’t fit. The hooker ones fit perfect according to him and rhot and a few others
