thanks for the help guys...it didnt have a tag saying it gets hot...hopefully i will have some pics up soon...my camera is a best buy for repair...cannon a70...maybe i can get it back monday of next week...ill see if i can describe my tank setup a little better until i get some pics...ok i built a platform 44X14"..just made a frame with 2X4 and on the top is 3/8" pressure treated plywood...i sanded it down good and sprayed it with flat black paint...the tank is a ART 5 gallon slim tank..it is centered on the platform but is closer towards the front of the platform closest to the tire humps...my compressor is directly behind the tank in between the tank and rear glass...beside the compressor is the power and ground db blocks....and between the blocks is my 40 amp MAS relay...all wiring going to the valves mounted to the tank,the compressor wires,the db blocks, and the realay are all ran through the platform through holes....everything is clean this way no scattered wires nothing looking like a rat nest....in each corner i drilled two 3/4 holes...the driver side kinda beside the hump in the bed where the gas filler neck is one hole has my CCE switch box wires,4 1/8" airlines for my dual needle pressure gauges mounted in my a pillars bound with split loom to prevent rubs, and the ignition wire for the pressure swicth..same side other hole i have my 1/2" airline coming through with 1/2" heater hose around it to prevent possible rubs....on the passenger side corner is 2 more 3/4" holes...again one hole is the airline with heater hose and the other hole is where the 8gauge gound and power wires come through....this is where i stand waiting for xmas when i get my milwauki recip saw, and milwauki 4.5" angle grinder...its just a waiting game now...hopefully a few days after xmas i will have the front broke loose and the pockets cut...since the 1/2" airline is allready ran up to the pockets with plenty of slack i can just connect it to the bag and put it back together...i cant wait:sawzall:
