on mine they come in 1 1/2" ... but this is on a 1st gen blaz... on your 2nd gen cab it might be different... mot sure how the innerbody metal differes between the two...
yeah itll work on a 1st gen s10... the only thing about using this style hinge is where the back of the hinge gets bolted to the cab... you will have to bolt the back of the hinge to the back of the cab and there will be a bolt head between the bed and the cab...nick-s-10 said:ok u did it on a first gen blazer would it work for a first gen s-10
there is no welding required to perform the mod... the only welding needed will be on the bodywork side to fill in the holes...BigDuVall said:1st Gen S-10 should be no different than a 1st Gen Blaze.
But, you made this look simple. It makes me want to do it, but I don't know how to weld and I don't have access to any welding equipment. How about you suicide my doors for me?
you dont need to waste that much money on those hinges for your hood... you can get a set of hood hinges from a mid 80s Buick LeSabre to suicide your hood... check my sig for a link to my how-to on it...fauker said:I'm going with SD kit,, but that is a very interesting way of doing it!!! I think I;ll suicide my hood using those,, maybe they'll work!!! also,, I'm station wagon open my tail gate,, those will work dandy!
bolted in huh? says right there you welded it..Nite Dragon said:now to mount the striker... i climbed inside and saw where the striker needed to be mounted, then marked and tacked it just to make sure it worked them welded it when i was satisfied it did. this pic was taken after the stock hinges were removed but you get the idea.
cool deal, I have been throwing around the idea of suiciding a door, maybe both, but Im quickly running out of money for my truck.Nite Dragon said:yeah its a long tedious process... it took me prolly 18 hours to get the door suicided and the stock hinges removed.... which took the longest... still have to finish the striker and latch... so yeah i guess 24-25 hours is about right...
