Homemade suicide door how-to...
24024 Views 57 Replies 21 Participants Last post by  Rhotpursuit
Hey yall... thought i would post the how-to for suicide doors tha Phatfarmer2 wrote up on Blazin Low... all the pics are from his truck... havent gotten around to taking any of mine... but youll get the idea...
This can be an entirly bolt-on process as well... thats the way i did mine... although there will need to be some welding for the bodywork... but none is needed to perform this mod...
First off i bought a set of Jeep Wagoneer hinges. They are also on old jeep Cherokees(sp), also old 50's - 70's style trucks have similar style hinges. Expect to pay less then $20 for the pair. I got mine for $15 both sides. Now what year are they off of? who knows just make sure they look like this.
Status
Not open for further replies.
1 - 20 of 58 Posts
ok so make sure you leave your door on the hinges until i say remove them!... lol
now its time to get a tape measure and a level
now you want the hinges spaced out about 12 inches from top of hinge to bottom of hinge roughly.... If anyone wants i can get my exact measurments i used, but it should look like this, any thing that is close to this will work.
ok i dont have a pic of this, but i welded a nut onto the back of the hinges so that it would make things easier to mount. i also chose to mount the hinges from behind for a somewhat cleaner look.
i then cut out the part where i marked and then installed the hinges and drilled the holes then bolted it up.
now this might be a part that some people might not like, you have to notch the hell outta the inside panel so that the hinges can swing in.. not a big deal for me since i will just fiberglass a few bubbles into the interior trim panel. here is what the notching will look like.
now its time for reinforcement.... now lookin at the door jam i put an 1/8 piece of steel behind there to tie the two hinges together.
ok now for the inside of the hinges.... i took a piece of angle iron cut to the size of the hinges from top to bottom (both) i then welded nuts on the back of it.
Then bolted it onto the hinges where the hinge has a hole for it to mount to the original jeeps body.
now that the hinges are attached together, the rear still need to be mounted to the body so that they dont flex, now this is what i did temporary and it works, i still wanna figure somehting else out to make it work better, basically i drilled throught the sheetmetal inside then through the angle iron attached to the higes the bolted the two together.
ok so now the hinges are in and all together.
Now its time to move to the door. stock latch and striker are removed, door handle also. Get rid of all the linkage, everyhting that ran to that latch it just gets in the way. take a 1/8 plate and weld or bolt it to the rear of the door, where the hinges will attach, either on the inside of the door or on top of the door skin, i chose inside but im not sure why.. lol this is what my 1/8 plate looked like, i had to notch it for the window track.
Now from the inside close the door and see where the hinges will mount to the door. you will only use two of the three holes in the hinges. so take a drill and drill those two holes into the 1/8 steel plate. Make the holes at straight as you can.. and drill them the same size as the hole in the hinges.
Now its time to take your door off. get a punch and tap out the hinge pins. I have power windows and locks so i had to remove all those wire, (which i extended later on to make the window function again).
i used two floor jacks and jacked up the door and aligned the hole i drilled with the holes in the hinges and then bolted them together. (now u can just get a friend to hold the door up but i was doing it by myself so i had to improvise).
do a test swing of the door to see how it opens suicide and make sure you wipe the drool off youself.. hehe.... it should be perfectly aligned just the way the door was when it wasnt suicided.
ok so now how do we latch the door shut? hmmmm.. well this is what i did... if you are doing the passenger side door then use the driver side latch on the passenger side... in other words just use the opposite side latch on the side you are suiciding....
ok now with that said i cut out the sheetmetal where the latch mounted (from the opposite side door) and then cut out the metal and then attached it by welding or bolting it to the front of the door.
now to mount the striker... i climbed inside and saw where the striker needed to be mounted, then marked and tacked it just to make sure it worked them welded it when i was satisfied it did. this pic was taken after the stock hinges were removed but you get the idea.
ok so now that that works you need to figure a way to get in and out. i installed rear glass solenoid to open the door, then wired it up to my remote. but i didnt stop there. on the outside i shaved the handle then took the key hole and welded it towards the front and then attached the linkage to the latch
but i didnt stop there i mounted the stock handle at the bottom of the door panel but in a vertical position. its hard to see in the pic tho.
ok now for the final touches :
I extended the wires so that my power window would work, thr wires now enter through tha back of the door where the hinges are, i also had to run wires for the solenoid, and my M3 mirrors and done light switch.
also small notchs will need to be made in the door panles for the latch and the hinges.
Now remove the stock hinges off the door and the jam, they are a bitch to get off, what i did was drill out the spot welds then used an air chisle to break it off.
then i welded up the holes left from where the wires routed throught the jam and on the door. then, a lil bit of grindin and bondoin, and then primer and this is what u get
and here is your final result! the doors will open a full 90..... but this pic doenst show a full 90 so ohh well u get the idea
does he have a pic of what it looks like inside, where he cut out pieces of the panels?
Wow, I cant believe those dont sag...
Aww u should have made it so the door goes into the back of the cab instead of swinging out like a barn door. but still looks cool and now your hood and doors match.
they dont sag at all... the front of my door was a little too high so i tried to push it down to get it where i wanted it and it didnt move at all... its very strong...
dagreenmonster... i dont think he has gotten to that part yet... neither have i...
how far do they actually stick into the cab where u have to notch it out? im interested in doing my doors this way, so i just wanna have some backup info
1 - 20 of 58 Posts
Status
