1 - 2 of 2 Posts
5 speed 4 door blazer
Discussion Starter #1 (Edited by Moderator)
Hi guys, just want to share how my homemade 4 dr S10 Blazer C Notch is coming about. I'm using 1/4 metal but I think 3/16 would've been good enough.
I cut out a small piece of the body but is nothing structural on the body as you can see in the pics.
My goal is to install airbags and to be able to go as low as I can without cutting the floor or into the wheel wells. I know eventually I'll have c notch the rear crossmember but that's easy and I also ordered a set of 3 inch tapered drop blocks which should help alot with the driveline angles. I tried with 2 inch blocks and still had about 4-5 inches more between the top of my tire and the wheel well. There's also a lip on the wheel well that if worst comes to worst I'll bend it flat by hammering it.
1 - 2 of 2 Posts
