98 Noma ZQ8
I know i've seen this here before but i couldn't find the thread.
when my engine is shut off, and the key is OUT of the ignition, my highbeam light is on on my dash. The airbag light is also on, but thats because i removed the sensors.
if you guys could tell me how to fix this or even point me to the right thread i would appreciate it.
Do have Daytime Running Lights?
If you messed with them at all, it can illuminate your Hi beam indicator, therefore sending 12v back to certain circuits in your guage cluster.
You could try removing the DRL relay, and see if it cures your problem.
But, since your SIR (Supplemental Infatable Restraint) system is disabled, the easy way would be to remove the bulb. This just might cure your Hi beam indicator problem also. Because your SIR system is back feeding 12v to your gauge cluster thru the bulb, too.
98 Noma ZQ8
i have my DRLs disonnected, i pulled the fuse for them a couple years ago and never had any problems with them.
