Alright, I just bought a 9000K HID kit online. I own a 95 s10, 2.2L 5-speed. I have the sealed beam, but I bought a conversion kit, so now I can put any h4 bulb I want to into it, it also has angel eyes. Now my question is, I installed the HID's, and when I turned on my lights, only the passenger side worked, the driver side flashed twice, but stayed off. I read it takes a lot of power to turn them on, and in the instructions it told me to replace my headlight fuse with a 30 amp fuse, but the problem is, I opened my fuse box (in the door), and couldn't find the headlight fuse, anywhere, I found the DRL fuse, but not the headlight fuse. I left the one HID on, and pulled out every fuse, and still the HID stayed on. So, where the hell is the fuse for the headlights. I know I have a relay in the glove box, but how do I get a bigger one, so both of my HID's will work?
Also, my hid's have an HID low beam, and a halogen high beam. When I turn on my high beams, the HID (low beam) goes off, therefore I would assume, I wouldn't be able to see as much, because it's only a halogen bulb, not an HID. How can i get it so my HID will stay on when I turn on my high beam. I read about kits for the 98+, where you have the composite headlamps, but I have the single headlights, (high and low in the same housing). Any help would be appreciated, thanks.
