fallen angel
i have a 95 dime and want to change the headlights to hid but dont't know exactly what i need, do i change the housing first, cause it still use the glass sealed light, do i need the H4 headlight conversion kit first, or the projecotr headlights, a friend of mine got his done on his 02 gmc fullsize for $400 including bulb, wiring, and ballest, on a set of projecoter housings cause he has a denali conversion kit on it
redrider said:
my conversion for my 96 with the housings(2), wiring harness(most expensive thing) and 2 light bulbs cost me between 100-150 bucks!
Are you sure that you got HIDs the ballasts should be more expensive than the harness
to answer the question you will probably need housings with a clear lense and a bixenon projector with the rest of the hid set up
no to the HID things....he mentioned in his thing bout the H4 conversion and the second guy wrote u have to get the conversion kit, so i thought he was referring to the H4(second guy that is) and so i wrote up on how much it costed me to get the H4 conversion kit
on a side note.....circuit city sells wanna be HID bulbs
