1999 S10 with Gen I 350 W/Tri Power and Muncie M20 swap still in progress.
Hi to all I'm a newbie here. I have a 99 S10 with a 1969 4 bolt main 350 and Offenhauser Tri power set up in the truck now.. I replaced the automatic transmission with a M20 Muncie what length drive shaft do I need to use to make this work the automatic drive is to short. Thanks for the help
You really need to measure it.
Put the yoke in the back of the transmission then measure from the center of the U joint seat all the way back to the pinion yoke center. Stock standard cab with factory equipment is 33" center to center.
Font Screenshot Number Electric blue Darkness
Rectangle Font Line Material property Parallel
It's kind of an unwritten rule that you can't post those kind of specs without pics...we'll wait....
