HEy slizzamend >Need a bodydrop pic> Do you have any pics of the front of the cab along the fire wall. I need to see what you did. I have seen one in person that did not look right want to see what you did.
Rocker Draggin Member
Uh....ill try and get you some pics.....the one thing that you will have problems with is gonna be the Clutch master cylinder hittin the a-arm at 0 psi.I had to cut and reinforce the a-arm around it and shorten the clutch pedal.Also check your main wiring harnes that comes through the firewall on the passenger side...mine was sitting on the exhaust manifold.
Thanks> My friend has problems with his hitting but my clutch is some kind of one of setup that is afro enginered beyond belief . I could show you some pics but i wont have any problems with it clearing, Do you have any pics of the notchees arm my friend was going to get the tubular arms If you have any pics of that i would be grateful i could save him some cash
