Is anyone one having problems with their 2.2's hesitating real bad. Mine is getting worse and worse everyday. it will almost stall out at lights sometimes.
I have recieved info on the service bulletin for the plugs and wires but didnt know if anyone else has had this problem before.
G
Hey Noma whats up?
I have had some probs with mine too and I found out there are a few things we can do to fix them.
First try changing your fuel filter, easy to do and takes little time.(I can give you instructions if needed.)
Second is the plug wires, these are covered under warranty for 70,000 miles for free replacement so take it to the dealer unless you want aftermarket.
Third thing is the fuel pressure regulartor, sometimes these are the cause of the problems so try this if the others dont fix it.
