misses truck....sometimes
ok guys, im learning as i go with my s-dime.....im working on bags right now, and have some questions..for the complete kit, front and back, what all do i need.....
- compressor
- air tank
- switch panel
- pressure switch
- 4 bags, obviously
- fittings, and air lines
i know there is more, but what is everything i need to have a set of bags. Its an 82 s-10 by the way. Also one more thing, what is the absolute cheapest i can get a kit for??
check out the stickies at the top of the page, they might help ya out. as for the price, yes there are some setups that you can get for under a grand. you can get a fb setup for around 800 I believe. You should realy save a little longer for the fbss kit, the truck will handle alot better.
The cheapest you could get an easily upgradable F/B kit for is about 1050 or so. IRSd_mini sells it. Hit him up. I'm sure he can help you decide what all you need to get started.
lays frame on 22's
never_finished92 said:
heh.. didnt mean to steal your name or anything...i just thought of it when i was making a username....and i thought, well, as much as i have planned, ill never be finished :bash:
no problem man, there are a couple other guys using the same name on other sites too. you're right though, no one's truck is ever really finished
the spl king
i hear u on that
im not even close to even thinking about being close to being done yet
most people at my job trip out on the air bags, but then some talk sh*t(haters) because my truck is always being worked on
everytime i turn around
most 3/8 valves are going for around $35bucks each
its about $140 for 4
witch isn't too bad
be like me
buy one part at a time into u have the hole kit
took me almost a year of buying parts one at a time
being only an A1C in the AF
thank god for everyones sells and ebay
