I recently shaved factory tails and molded Supra's into the tailgate of my 2000 Xtreme, has anyone have any info on how to wire the bulbs up? The problem I am have is on my truck the brake, park, and signal light is ran through the same wire because they use the same bulb and on the Supra's they are ran through seperate bulbs. Any help is greatly appreciated.
former title junky mod
Well, FBI sells what they call a TAC module that seperates the signals, but its 99bucks. The last time I checked advance auto parts sold a box the split the signals and it was made for trailer wireing. You might want to check the trialer wireing section at the parts store for something similar
Horsepower Fiend
Since the Supra light have a seperate signal all you really have to do is make sur that you ground each bulb seperatly is all. Shouldnt be too much of a big deal. Although you may have to run a seperate wire from the front signals to make the rear ones work and have brake lights at the same time.
