I know somewhere there is a thread or post on this, but please
help an old fart. I have a 92 slonoma and bought full clears
for the tails. I want to put LED bulbs in. Will I have to get
some kind of gizmo for the blinkers to work right and can
anyone suggest LED "bulbs" for the tail, brake, and reverse
lights for these clears ?
Or if someone can direct me to the how to, post , etc, on how
to do this, please be so kind as to enlighten.
Thanks for any info
bg.
Founding member of DA
search for v-leds
BumblBXtreme
in the front signal lights if you put leds you will need a load resistor to stop the hyper flash and the problems. As for in the back you could possible need a load resistor also. the signal markers(small ones that face sideways) are 194, and the tail lights are 3157 im pretty sure
4x4 v6 blazer
Load resistors are a band aid fix for just installing the correct flasher thats only a $20 part.
Thank you for your replies. Yes, I will go with a proper flasher
for the system.
