1 - 2 of 2 Posts
I am having some difficulty removing the oil galley plug that sits behind the camshaft sprocket on my 96 2.2L.
All the advice I could find online said to drive a small screw into the hole and then use a claw hammer to pull out the plug. Unfortunately I have tried that, and each screw I have driven in has just pulled out, widening the hole in the plug but failing to budge it. Does anyone have a plan B to remove this thing?
The only thing I can think to do is spray some PB Blaster in there to loosen The bond between plug and hole, but I didn’t know if PB Blaster in there would damage the engine, nor do I want to push those metal shavings into the engine either.
Pic attached to show its current state.
Thank you in advance for any help you can give.
White Light Automotive tire Rim Bicycle part
time to get cereal
At this point it looks like you can just stick a flat head in and rip it out.
1 - 2 of 2 Posts
