Bit of grease or anti seize on the shaft and steering box splines
Then a few light hits with a rubber hammer where the rag joint is. If you dont have a rubber hammer you can use a normal hammer with a piece of wood in between the shaft and hammer to avoid damagingthe shaft. .
You of course need to remove the rag joint to do any thing first. Reinstall it once the shaft is on the power steering box down snug.
