Nothing is bolted together like the guy above you saidWow , Is that a Wicked Drive Line Angle at the Pinion , or What ?
Won't be needing any optional massage seats.
They'll be plenty, as is , on this setup.
This is a good observation. Will those even fit the plates on the bottom? They need to match the diameter of the axle tube.The radius on those u-bolts looks a little large. Did you compare them to the stock bolts?
Yes the U bolts are bigger than they should be, the axle tube is like 2.75" and these are 3" u bolts , they came with the blocks. And no it wasn't a permanent solution I planned on redoing my drop blocks with steel blocks after I figured out if 3" drop was what I wanted, and if it would work without doing a bunch of other things. This is my first time lowering a vehicle so the simpler the better.The radius on those u-bolts looks a little large. Did you compare them to the stock bolts? Some people use set back plates to gain a little room. I’m not sure how much room there should be on the slip joint. I’d be inclined to have the drive shaft shortened. It’s probably way past due for new u-joints anyway. Check with a local d/s shop on cost. It’s not fancy or glamorous, but it won’t leave you stranded either.
They fit but have to be slightly pinched inwards and yes I know this is not the safest option, this wasnt a permanent set up. Was going to get Ubolts made at a local shop, and also swap out the aluminum blocks with steel blocks after I figured out if the 3" would work/be the drop I wanted.This is a good observation. Will those even fit the plates on the bottom? They need to match the diameter of the axle tube.
I'm thinking this may be a "universal" kit?
