So to start this is my first time lowering a vehicle, I tried installing 3in tapered blocks (tall side towards the rear) but can't get the blocks to line up with my Axle. I can get one side in but the other side won't line up. I've tried rotating the axle but still can't get them to line up, it will only rotate upwards, does it need to rotate towards the ground in order for it to line up? Do i need some sort of shim? I wrote down my pinion angle before attempting to install the blocks does that have something to do with it?
