I have an 84 blazer 4x4 with a 2.8 and a 4 speed. the engine has 184,xxx on it. it runs strong but there is a light knock in the top half. I'm thinking lifters or rockers but i have no idea. and also why is this damn thing a 4 speed, i never heard of a 4 speed s-10 blazer??:rolleyes:
probably rockers, try tightening all the rockers 1/4 turn. or, if you're hardcore about it, pull the intake mani and retorque them to factory specs. i believe its no slack, then 1 1/4 turns further. sounds tight, but it works great. check a chiltons first. if it's lifters, replace the cam at the same time if you have the cash.
thanks man i'lll have to try that when i get some free time.
do you have any idea why this thing would be a 4 speed either???
Club H.A.S.T.E Turtle
It's a auto tranny correct? Chevy used a 4 sp Auto and a 5 sp Manual.
If you don't have one, I'd get a Chilton's or Haynes. It will give you specs on what to torque almost every single bolt to as well.
no..
No its a manual trans, aka stick shift. its a 4 speed stick shift and i never heard of this before soo i dunno.:dunno:
They made them
The Borg Warner T4 (4 speed) is almost the same as the T5 (5 speed) and some of them were used in the early years...:werd:
