Ok here is the deal I'm bagged so I had to move stuff in the engine bay. I got the battery in the bed with a wire run to the 175 fuse that is under the battery tray that also runs straight from there to the starter. I try to start the truck and the starter just clicks. The battery is hot and we even tryed to jump it same thing. Do I need to run a wire straight from the battery to the starter to see if i can get some more power.
:wtf:
Do I need a gas mask?!
dude keep as many original grounds as possible i would keep that ground on the block, and refer to a manual about different grounding points. You should use 4 gauges ground wires on the block to frame. and 0 gauge on the battery
