Got Stones????
Got everything hooked up and i have a severe leak at my water trap....it is an el cheap cambell hausfeld from home depot....it is leaking bad where the clear cup screws into the metal...i guess the rubber o ring is bad from the factory anyways......i air the front bags all the way up at 120 psi......should they stay filled even though the tank leaks down to 0 psi over night or does the valves have to have back pressure that is in the tank to keep the valves closed......im just wandering???? by the way i got a more expensive water trap last night but havent had a chance to go to the shop and try it out.....
Soon to be bagged
which means ya gotta get a check valve :(
