Shit's Weak
i dropped it 5 inches in front with belltech spindles and coils. and on the passenger's side, the outside of the tire is closer to the inner fenderlip than on the driver's side by probably a 1/4 inch or more. therefore it rubs really bad on the passenger side over any dip at all. i had an alignment done a while ago after i did spindles but i didn't align it after i did the coils a couple days ago. could the problem be related to camber because i haven't gotten an alignment or could it be something else. any thoughts are welcome. thanks in advance.
John
Shit's Weak
i know all about the chevy lean and i don't think that the lean is the problem. i'm currently a half inch lower on the driver's side which is normal and i'll be fixing that soon. the problem seems like the passenger tire is out further(not higher) from the center and therefore closer to the inside of the fenderlip. in other words, it seems like i have a spacer pushing my pass. wheel out further than my driver's side. i suck at explaining but i still need hints at what the problem could be.
