Go Kart Draggin Member
My cuz has a 95' dime, it's chuggin when its in the low rpms (2k-3.5k) above 4k'ish its fine. We replaced the plug's n wires and the injectors with slim to null results. Theres 145k on the electronics, the block has 20k. What could be wrong? Any one else have this problem. Any suggestions would be highly appreaciated
could be three things, vacuum leak, vacuum sensor going bad, or your egr. check your egr diaphram by sucking on the tube that leads to the diaphram, if it makes a difference then its working. if it doesnt then that means its bad.
just check your lines, and if something looks old in any way, replace it. also, check your vacuum resevior, its like a black orb, should connected to your hood on the drivers side.
Fuel filter was replace less than 2k ago so its not that, We'll chech the vac lines and egr when I see him this fri.
