1 - 2 of 2 Posts
so i bled the brakes on my 02 2wd s10 last night, great pedal when the engine is off. let the truck down, go to back out, and the truck doesnt stop till i bottom out the master cylinder and only the fronts work. so i jack it back up and put it in gear. nothing.
so i take the tires off to see if maybe the drums are out of adjustment. they are fine. i dont see any fluid leaking out.
maybe i sucked in a bunch of air? the fluid did get really low when i was emptying the master cylinder (i didnt want to mix the old and new inside the master cylinder, i just wanted the new to push the old out)
the truck has abs if that matters. idk if there is a special trick or what to these. ive bled tons of cars and never gave it a second thought. in fact i just did my civic right before i did the s10 and thats fine.
Discussion Starter #2
the e brake works perfectly as well. i have to drive 4 miles to work, so i might use that till i can look at it tomorrow morning
1 - 2 of 2 Posts
