I’ve got a 1995 GMC Sonoma sls with 2.2L 4 banger. I just replaced my clutch, flywheel, throw out bearing, and clutch fork release. 1st and second are perfect. But if I get to about 25mph it startes shaking. Faster I go worse it gets. Anything helps.
the new guy
is your driveshaft ok and lined up properly? is yours an extended cab?
maybe your driveshaft center support bearing needs replacing? the extended cabs have a center support bearing that can go bad. if yours is a single cab, like my Sonoma was, maybe you need some u-joints changed? mine were bad on the back of the driveshaft and caused shaking
It’s got a extended cab but and it seemed to be pretty spot on in the center but when I get off work I’ll look it all over thanks man
Just Asking.... Flywheel Bolts torqued properly?, also ... is the Bushing in the Crankshaft straight? (don't ask how I know). My experience has taught me whenever I replace something and things aren't right somewhere else.... go back and check the last thing you touched... also was it shaking before replacing all of these parts even a little? The shake could have become "enhanced" now that other things are not as worn.
Good Luck,
Scott
Thanks everyone. I replaced the u joint and I joint bolts and now it’s the shaking is gone. First we tried tightening them and went on a drive. The drive shaft fell at about 25 mph and the u joint snapped. The bolts on one side snapped. All good now tho lol
