Takin off
O.K. yall,you guys need to put a few extra pounds in the bed,throw on some drag radials ,slicks or any other tire with some wide sidewalls.Ifyou are runnin street radials you need to practice your launch.Give it hell off the line,let off it real fast ,then get back in to it.This will really help your 60 ft. times even if it sounds slow.Do NOT do smoky burnouts with radials,the heat makes them to soft ,you only want to clean them off with one quick ,short turnover.Dont drive through the water either.If you have an open bed,open your tailgate,this is also good for a few 10ths on the top side.Practice makes perfect.Good luck at the strip.
