I have a 82 s10 that is stock ride height and I have a set of 1999 15x7 steel wheels that I want to put on it . What would be a good size to put on it that is at least a 235 wide?
IOWABOB said:Those wheels will fit too tight on the hubs unless you grind them out, if you force them on, they will be on forever. The centerhole on 97& older wheels will fit. (also, one other post said use 235/70/15, dont, they are too tall, will hit the rear of the front fenderwells on turning)
