i have a T-5 NWC on my way to mammoth, i lost 3rd gear, now it wont shift into 3rd, and it makes weird noises at idle sometimes, like something is rattling around inside. any ideas suggestions?
When you hear the noise like **** is in the transmission push the clutch in and see if its is quite again if so then u will need a new clutch releas bearing and for third gear i had the same problem and still having problems it was the syncromesh and 3rd and 4th fork was bent.
