I dropped it using eibach springs and belltech blocks. i used the spacer. the driver front is 1/2 inch higher than the other side, and the passenger rear is 3/4 inch lower than the other side. what's up? take the spacer out?
Did you measure your truck before you lowered it? You might not have needed to use the spacer. Only the trucks that are lower on the drivers side need it.
no, i never measured. i just hardly ever see anyone with a blazer tell if they had to use the spacer, i just figured since all the s-10's needed it, mine would too
I didn't use the spacer on my blazer, but mine does lean a little. at first, i had about 1/2" lean and I did the sway bar end link trick, it helped a little. I have about 1/4 difference now.
