I have a 97 GMC Jimmy with an auto tranny. The dipstick and tube was rusted so bad that I had to soak it in wd-40 to get the dip stick out. The dipstick and tube are full of rust. The dip stick looks like it has been sitting out in a field for 10 years. The fluid is up to level, looks fine and smells fine. I figured if there was a bunch of water condensing out in the tube that it would get in the fluid and make it milky. The trans is shifting fine and working good. When I put the dipstick back in, you can feel it scrape-ing the rust all the way down the dip stick tube.
Have any of you experienced this problem. What do i do? Is there a vent tube that is clogged up?
John
96 S10 Pickup 4x4
I know that this thread is an old one but i just bought a 96 s10 and my trans dipstick is the same way the fluid smells fine and looks great but the dipstick looks like shit most of the way down. What should i do to go about getting it fixed??
Just another asshole
call the dealer... they have an updated tube and dipstick ... i do recommend tho, after you do this, change the fluid and filter!
Blown ex ***
yes, replace the tube and stick. then drop the pan, clean it out, and put it back on.
