Thank you for these instructions, they work exactly as mentioned to get to the blend door actuator. But I don't think that is the cause of my problem, just one of the casualties. A brief note of my situation, I have a 98 s-10 pickup. When I got it two weeks ago, I first noticed the a/c didn't work, I could not differentiate between hot and cold air, but all of the vent settings worked. After about a week, it started blowing hot air out of the floor vents all on it's own with the vent setting know turned "off", nothing was turned on at all. After this happened, I lost any control of the vent settings knob that I previously had. This happened the day I took it to the local chevy dealer to have it looked at. Of course, they did a bunch of stuff that didn't fix the problem and charged me for it. After reading this forum, I yanked the blend door actuator and discovered that this unit only switches the door between hot and cold air, it does not switch between the different vent settings. I put the electrical plug back into the actuator and started the truck to operate the hvac controls and the actuator did not move at all. I also noticed that the vent control knob is vacuum controlled, and the a/c compressor kicks in when the knob is turned to max a/c, a/c, defrost/floor, and defrost. I am now thinking that it may be a vacuum problem. Would I be correct in thinking this and, if so, would the problem maybe lay in the switch itself or the vacuum source that feeds the knob? Any ideas on where the vacuum source comes into the dash to feed the vacuum lines that go to the control knob?
