1 - 12 of 12 Posts
Okey so on the way home tonight i kicked the heat on and it wast nothing but smoke/stem. What in the world would cause this?
mr. clean
check for water under the pass. side dash. if there is any water leakage you need a new heater core. i don't know why it's steaming, unless you're running hot,
i saw what you did there!
hot water is steam
especially if cold out
duh?
heater core sounds like its blown
time for a new one
New Old Timer
Definitely sounds like the heater core.
I just did mine a couple of months ago.
PITA, but doable and necessary, unless you being cold.:2far:
Discussion Starter · #9 ·
Yea I have never seen one do like mine did. But I turned it on this moreing and no steam? I dreed the hell outa this. Any tips on goin about this?
mr. clean
sorry, im not the for most expert on the subject. i just knows what i think i's be knowin.lol
mine was clogged up last year and was the orig to my truck (amazin!!) so i did like you and searched on the process of how to change it. some said "ya gotta pull the dash down" and others sugguested "at" it but i couldnt get a stright answer on the process so i dove in and step by step broke it down and it is easier to do than my firebirds and doing one on my birds is a 45 min job and thats even pulling and putting up the tools.
i can speak for a non AC truck. on the pas side there is a cover over the heater core, pull all the screws on this cover and the cover should pull back and then drop stright down. you will see the heater core and the rest is obvious. if you need any further help just ask.
BTW, the dash DOES NOT have to come down to do this.
1 - 12 of 12 Posts
