For a mild street application look at the flow numbers from .300-.500 lift. If you use a cam with .450 lift and you select a head that flows the best above .500 lift your combo will be weak. 441's have a 73 cc chamber according to Car Craft. I've heard the stories about cracking 882's but I've never seen it happen, wondering if the heads were heavily ported before cracking, IDK. I'd say go with the 882's if you're on a budget and if you want a high revving motor/big camshaft junk them both and go with aftermarket heads.
