Madman's got it right. Pulling the inner skirts will save you sooo
much time. Get it up on jack stands, pull the wheels and tires, the
inner skirts and the exhaust bolts are staring right back at ya.
Very easy to access.
JBA exhaust flange to head gaskets BITE. They're hard to seal.
I would get the best exhaust gaskets you can. Genuine GM will work
good as well as Fel-Pro, and Mr.Gasket Ultra Seals. Also get a tube
of Permetex copper based silicone. You'll want it to seal the cone
to y-pipe junction, as there won't be any gaskets. The JBA's use a
welded on inversed cone for the y-pipe to connect to. I dumped
the bolts JBA is sending with their headers and got GM small block
header bolts and lock washers. The size is 3/8-1"- 3/8" 6 point head.
Being the small block come in 3/8" 6 point head they'll allow you to get
into the tight area between the bolt and the header pipe so you
can torque all bolts down much easier. The bolts themselves where
grd 8. Worked excellent. Got em at a local speed shop. Yer gonna
find you may have to bend the oil dipstick tube around to make
it fit right. I had to pull mine out and bend it just right so I could
get it to mount into the block decent.
Last, I used Mr.Gasket Ultra Seals witha small bead of copper silicone
around each port area on both sides of the gasket. Very small bead.
This insured a leak free install. You may have to change out num *1
and num *6 spark boots to 90* boots to keep them from burning on
the header tubes.. For bolts down at the y-pipe to header collectors
I used 3/8"x 2.5 stainless grd 5 allen head bolts and stainless flange
nuts. A lil hassle to install and get to, but they have NEVER come
loose.
I bought a couple of 3/8" studs and just screwed them into
the head on each corner loose-like to hang the header from, while
I got the other header bolts started, then I pulled em and replaced
with header bolts Made it reall easy to install the header and
exhaust gasket without messing up and fighting to hold the header,
and the gasket at the same time, while trying to get a header bolt
started..Very helpful.
It's all about taking yer time. If ya get to be in a hurry, it will drive
ya nuts. With two exper GM techs on it, you should be able to
knock it out in a day, if ya start early. Might take two days.
I don't know bout the new trucks, but on my 92, I had to pull the
pwr/str pump to access the back support bracket for the pump.
On mine it was bolted to the pump AND the num*1 exhaust studs on
the l/s. There was no other way to get to it unless the pump was
pulled. The bracket sits on the two and held down with nuts.
I had to pull the nuts off then the pump with bracket, lay it aside
then I was able to get to the two front exhaust studs and the nuts
that held the exhaust manifold to the head at num*1. A TRUE PITA !
if you have to do this, you'll need a pulley puller as I think the late
rides also have a pressed on pwr/str pump pulley
Other than all this, it was a pc of cake..and you'll have the
satisfaction of knowing that, yes installing headers on an S truck
is not fun, but after they break in you'll feel the diff. My ole ride
rolls pretty good for just the minor cr*p I've done to it.
Took me two weeks, but I like to fish too..HTH's and sorry for the
long post. But i didn't have anything else to do..
