I at one time posted the prt num for copper gaskets and I
could of swore they were for the 4.3's. I know I posted the
num for the Ultra Seals, but once again it was a long time ago.
I found this. Hope it helps. By the way, are you putting a small
bead of copper silicone all around each port on the gasket, both
to the gasket to head and gasket to header flange ? I put a
small thin bead around each both to the head /gasket and
header/gasket. It has never leaked. I read over at a hotrod
forum that's how the 305 and 350's are done..The copper
silicone is made by Peremtex and works killer. Infact that's
all I have on the y-pipe to header collector flange. A med bead
or silicone and 3/8" x 2.50" grd 8 allen bolts and and grd 8
flange nuts. The whole thing has stayed leak free. The Ultra
Seal gaskets along with the silicone really worked out well
for me..Just wondered if you had tried a sealer. Anyway, hope
it links.
Update. I did write the num down but had to dump it.
There are copper exhaust gaskets made by Mr.G. They're also
made for the 4.3 up. Problem is they're for the 8 cyl engines.
They don't make a copper for the 4.3 in the 6cyl configuration.
I knew I seen it before, but doesn't fit our engines. If
interested the Ulta Seals are prt num 5958. It's in the link
below, as well as a full listing of Mr.Gasket's seals and gaskets.
Course if ya just HAVE to have true copper gaskets, there's
always Sanderson. I think they go for around 60.00. If you've
never heard of Sanderson Header before, just ask the ole
hot rodders about em. Sanderson is considered one of the
best when it comes to custom exhaust..I'm done now, good luck
with the project.
www.mrgasket.com/pdf/Gaskets.pdf
