1997 2.2l manual trans. 165k
So recently my head gasket blew out due to a bad radiator that I didn't notice immediately and it overheated. After a change I thought all was peachy and thought I had fixed the radiator problem with a new hose and clamp. Not so. The radiator entirely gave out and lost11 all coolant on the drive home after work. I realized it halfway and pulled over to let it cool down. Upon removing the radiator cap it blew off and I noticed the coolant was dark. After letting it cool I added water and drove it home but it stuttered and smoked white smoke. The tell tale signs of a gasket gone bad in between a cylinder and the coolant channel. So I slugged it home and tore it apart again. Now however, I am stumped. Upon inspection of the head gasket, it looks fine to me, and to the best of my ability the head itself does not appear cracked or able to dump and entire radiators contents out the muffler in a few mile drive (which it did).
So I have a brand new radiator, but I am stumped on whether to change the gasket and reassemble or if I should get a new head as a safety just in case. There are no shops near me that will inspect the head for cracks or warping.
Will include pictures. Any and all advice is welcome. I am extremely new to this level of detailed maintenance and I really want my little 4 banger to bang again. Lol.
Upon removing cylinder head this is the water inside the cylinders.
Right side is front. Headlock okay to me, a layman. There is a scratch (not a crack) between 1 and 2 where the silver coloring is.
Closeup of scratch. However I am convinced it's unrelated since water was collecting mostly in the 3 and 4 cylinder, and this isn't between a coolant channel and cylinder.
Close of head gasket on 3 and 4. The gasket material didn't come off cleanly and looks damaged on upper corner. Not sure if this indicates a failure of the material.
Close of 4 cylinder with residual gasket material left behind. Could this separation indicate a failed head gasket? This head gasket has only been on for a month.
