1 - 11 of 11 Posts
Hey guys I'm in the process of modifying the 5.3 harness to work in my truck and from the excel diagrams I got it looks like I need to Repin the fuse block which I knew that, and the connector that plugs into the chassis harness? I was not sure about this part.
Sent from AutoGuide.com Free App
Use your factory fuse block engine harness and mate the 5.3 harness to it so everything works like oem.
Did you guys extend any of the fuse block wires? I made my harness a little different since I didnt want my pcm wire running over top of the engine so I extended them enough to run around to the firewall and across.
Banned
Yeah its not easy & def time consuming & it sucks when you get it wrong.
I did mine by myself after reading Calebs thread about 100 times. LOL
1 - 11 of 11 Posts
