1 - 2 of 2 Posts
Full Fledged Member
What would a engine sound like with a balancer who's outer ring was pulled off (cause he used a gear puller to remove) then just hammered back together ( not aliged properly to ensure the timing marks were correct). I'm asking for a friend...yeah thats it.....a friends and not me. Well anyways the car in question is a 85 jeep cherokee with a 2.8 out of a FI camaro. I believe the balancer it the orginal from the jeep. thanks
Ps how the hell do u bleed the clutch on these things
If the outer ring is full thickness all around you would not have any real difference. Sure wouldn't trust this for any length of time though, once it came off it will again and could be disaster. Sounds like you had a bad day!
1 - 2 of 2 Posts
