i gots the same compressor and what i did was put a + style fittin with the saftey switch on one end and the pressure on the other end of the + then screw the other into the compressor and the other is for the line!!
Hope this helps!!!
I have a Civic now
Hello?
I looked at a buddy's compressor the other day and he just had the hot wire from the battery going to one prong on the pressure switch and then the hot wire from the compressor to the other prong on the pressure switch, is this ok to do it that way without using a relay??
Nathan:dunno:
I have a Civic now
SOLOMA said:
i think so thats what im going to do!!!!
Right on, sounds ok, the compressor didnt come with any instructions on how to correctly wire it up, also do you have a water separator with your setup?? I thought about gettin one from like sears or autozone, do they go in between the compressor and the tank or between the tank and the valves??
Nathan
