my bag brackets are bending....
is it cuz i dont have a bridge?
do i need to grind them off and reweld them or is there a way to bend them back?
User Registered
pics of setup? nevermind i found a pic and a bridge wouldn't help much with the brackets you have. if you could work with something like this bridge...http://www.suicidedoors.com/Generation2BridgeKit.php
or if you don't want to go that route, bend them back to shape and move them as close to the frame/notch as possible so there's not so much load bearing weight riding on the end of the brakets..
User Registered
or if you don't want to go that route, bend them back to shape and move the bags as close to the frame/notch as possible so there's not so much load bearing weight riding on the end of the brakets..[/quote]
sorry fixed that sentence^^^
we all know how it goes, but your truck looks real nice. so keep on keepin on...
naw i'll get on the phone with sd tommorow and talk to them about the gen 3 bridge kit. but all i need is just the upper plates and the steel tubing so hopefully it wont hurt too much... plus i have another steel tube that came for the shock mounting so i'll weld it in there to for a lil extra support
i wanted that bridge kit in the first place i just couldnt afford it at the time...
thanks for the advice.
