1 - 13 of 13 Posts
1.9 Proud Liters
Hey guys, I'm about to do a small system and was just wondering what y'all have had good luck with as far as a good head unit and a good set of speakers driven off of the head unit.
I was thinking a Kenwood unit with phoenix gold speakers (if they make them in 4x6 and 4x10)
I usually run a four channel, but I don't really want to put the money into it this go around.
that is a good start the problem I had was you could not get decent bass so I got a amp & a 8inch woofer 1 step at a time you'll get there
Its that dam ADD!
Kenwood X794 deck, JL XD4004 amp, Infinity 4x6 plates, Dayton 4" RS-100-4 mids in the back and some 6s in the kicks or doors if you can swing it, or something like that. Or instead of the 4x6s and 6s do a component set in the kicks with the tweeters in the kicks or dash
1.9 Proud Liters
Budget doesn't really matter, I'm installing all of it so I don't have to worry about the cost of installation at least.
I don't like JL amps, way overpriced...I'm just gonna be running them off of the head unit anyway.
The bass is already decided, I have an Alpine type-S shallow 10" in a sealed enclosure, and a Clarion G/H class monoblock. 400W.
Has anyone ran a set of kicker 4x10's in a first gen? I know they're probably the worst size ever, but I won't have to go modifying things.
I was thinking of sound stream's 4x6's up front.
1.9 Proud Liters
I really do like that excelon deck though, would look good in my truck. Thanks man
Its that dam ADD!
well its a SQ deck big time. T/A, good voltage, iPod or USB, good display, and lots of adjustments
Still, no way Id wanna do a 4x10. No modifying needed, just a plate with a 4" hole in the middle, easy. Hell, Ive wanted to do dual 4s back there off an amp. As far as amps go and doing an S-10, you dont have a lot of room and that amp has great power, its ultra clean and really small!
Mr. SQ
since budget is of no option, shoot for some of the best. Macintosh HU with a set of 4" components. Personally id piece mine together using scanspeak drivers.
1.9 Proud Liters
Discussion Starter · #9 ·
Here is how I did my other truck, I think I'm gonna do this one much the same.
As far as the dual 4" speakers in the back, how would you wire that? Can the amplifier built into a deck handle a 2 ohm load?
Its that dam ADD!
no the amp in the deck couldnt unless you you series them out to 8ohm, or ordered the RS-100-8 and parelleled them down to 4ohm
Its that dam ADD!
1.9 Proud Liters
Discussion Starter · #13 ·
Ok, ordered the Kenwood deck, thank you forklift, still debating on what to do in the dash, there's not much room in there. Now I remember why mounting those 4" rockford power series in my other truck was such a pain, I really don't want to do any hacking on this one.
Anyone ran the Infinity 4" component set off of their head unit (the 4x6 plate replacement)?
1 - 13 of 13 Posts
