has any one ever used golf cart solenoids is see they come in 36 48 volts heavy duty. I was wondering If you could just run 1 of thoughs insted of the 3 12 volts
· -=Hand Made=-
never heard of it or done it.. but based on solenoids are $10 a piece, so 30 per pump.. the golf cart ones are anywhere from 17-65.. i would imagine that the golfcarts use less amps i some cases ($17 soleniod) and more amps like hydraulic pumps ($65 soloenoid) in other cases
heres the run down on the golf cart solenoids not sure what some of it means . I think Im going to buy 1 and try it
Voltage: 48V
Continuous Current: 200 Amp
Inrush Current: 600 Amp
Break Current: 200 Amp
Electrical Life: 100,000 operations
Contact Bridge Material: Copper Clad AgCd
Stationary Contact Material: Copper Clad AgCd
Terminal Material: Copper
69.00$
· daily dragger
when i was juiced i used solenoids from a local electric ware house. they were big like the golf cart ones but one was good per pump up to 50 volts and they were rebuildable. sold for 90 a piece.(similar ones the ones summit racing sells) never had one fail and my ride was a daily. not to mention after i uninstalled juice i sold the whole setup to a friend who currantly uses setup and he never had a problem with them. thats almost 5 years of daily use now. who could say they got 5 years from a 10 dollar solenoid. no body i know especially since the ones i got with my cce kit lasted not even 1 week after i installed them.( they got stuck and burned up, luckily befor the pump motor did or destroyed my pump head or gear)
