Gen 3 LS:
Year Part # Duration* Valve Lift LSA
Corvette LS1
97-98 12554710 199/207 .472/.479 117
98-99 12560964 199/207 .472/.479 117
2000 12560968 198/209 .500/.500 115.5
01-03 12561721 196/207 .467/.479 116
PART NUMBER 12561721
116 LDA 115 INTAKE CENTERLINE. PRODUCTION 2001 6.0L TRUCK AND 5.7L LS1 CAR CAMSHAFT.
Lift: @ Cam @Valve (1.7 ROCKER RATIO) EXHAUST: 0.281 0.475 INTAKE: 0.274 0.463
Cam [email protected] Tappet Lift: Open Close Adv. Duration
EXHAUST: 71 BBDC 33 ATDC 284 INTAKE: 11 BTDC 87 ABDC 278
Cam [email protected] Tappet Lift: Open Close Duration
EXHAUST: 39 BBDC 12 BTDC 207 INTAKE: 17 ATDC 33 ABDC 196
Corvette LS6
2001 12560950 204/211 .525/.525 116 385hp
PART NUMBERS 12560950,12593206 2001 LS6 AND LS2 CAM DATA
116 LDA AND 118 INTAKE TIMING.
Lift: @ Cam @Valve (1.70 ROCKER RATIO) EXHAUST: 0.308 0.524 INTAKE: 0.308 0.524
EXHAUST: 65 BBDC 30 ATDC 275 INTAKE: 9 BTDC 81 ABDC 270
EXHAUST: 37 BBDC 6 BTDC 211 INTAKE: 18 ATDC 42 ABDC 204
Corvette LS6
02-04 12565308 204/218 .555/.551 117.5 405hp
PART NUMBER 12565308 – 2002-04 LS6 CAM CARD DATA:
117.5 LSA, 120 INTAKE CENTERLINE.
1.70 ROCKER RATIO Lift: @ Cam @Valve EXHAUST: 0.322 0.548 INTAKE: 0.324 0.551
EXHAUST: 69 BBDC 33 ATDC 282 INTAKE: 7 BTDC 80 ABDC 267
EXHAUST: 42 BBDC 4 BTDC 218 INTAKE: 19 ATDC 43 ABDC 204
Camaro/Firebird LS1
98 12557812 198/209 .500/.500 119.5
99-00 12560965 198/209 .500/.500 119.5
01-02 12561721 196/207 .467/.479 116
1.7 ROCKER RATIO Lift: @ Cam @Valve EXHAUST: 0.281 0.475 INTAKE: 0.274 0.463
Trucks and SUV with Vortec engine
LR4 and LM7
99 12560966 191/190 .457/.466 115.5
00-04 12560967 191/190 .457/.466 114
the 03-04 LM7 used the 12560967 camshaft
LQ4
99-00 12560967 191/190 .457/.466 114
01-04 12561721 196/207 .467/.479 116
01-04 LQ4 cam is same as Camaro, Corvette LS1 and LQ9 cam
LQ9
02-03 12561721 196/207 .467/.470 116
GM Performance Parts
Hot Cam 12480033 219/228 .525/.525 112
LS SERIES HOT CAM 109 INTAKE CENTERLINE 112 LDA
1.71 INTAKE ROCKER RATIO Lift: @ Cam @Valve EXHAUST: 0.308 0.525 INTAKE : 0.308 0.525
EXHAUST: 75 BBDC 32 ATDC 287 INTAKE : 27 BTDC 71 ABDC 278
EXHAUST: 46 BBDC 0 ATDC 226 INTAKE : 1 ATDC 39 ABDC 218
ASA 12480110/88958770 226/236 .525/.525 110
Gen 4 LS:
Corvette LS2
05-06 12574519 204/211 .520/.520 116 (also 06-07 CTS-V)
07 12593206 .524/.524 116 (also 08-09 Trailblazer SS 6.0L)
PART NUMBERS 12593206 – LS2 CAM CARD DATA:
116 LDA, 118 INTAKE CENTERLINE.
1.70 ROCKER RATIO Lift: @ Cam @Valve EXHAUST: 0.308 0.524 INTAKE: 0.308 0.524
Corvette LS3
08 12623063 204/211 .551/.522 ???
09-13 12631811 ???
Camaro LS3 (also 2009 G8)
10-15 12623063 204/211 .551/.522 ???
PART NUMBER 12603844 (replaced by 12623063) – LS3 CAM CARD DATA:
117 LDA, 120 INTAKE CENTERLINE
1.70 ROCKER RATIO Lift: @ Cam @Valve Exhaust: 0.306 0.522 Intake: 0.324 0.551
Exhaust: 66 BBDC 29 ATDC 275 Intake: 7 BTDC 80 ABDC 267
Exhaust: 38 BBDC 7 BTDC 211 Intake: 19 ATDC 43 ABDC 204
Corvette ZR1 LS9
09-12 12638427 211/230 .558/.552 122.5
LS9 12605227 CAM CARD INFORMATION:
122 INTAKE CENTERLINE, 122.5 LOBE DISPLACEMENT ANGLE
1.70 ROCKER RATIO Valve Lift: @ Cam @Valve EXHAUST: 0.328 0.558 = 14.2 mm INTAKE: 0.331 0.562 = 14.3 mm
EXHAUST: 84 BBDC 31 ATDC 295 INTAKE: 8 BTDC 89 ABDC 277
EXHAUST: 56 BBDC 6 BTDC 230 INTAKE: 18 ATDC 49 ABDC 211
Corvette LS7
06-13 12638426 211/230 .558/.558 121 LSA (also 14-15 Camaro Z/28 7.0L)
. (.591/.591 with factory LS7 1.8x rockers)
LS7:
120 INTAKE CENTERLINE, 120.5 LOBE DISPLACEMENT ANGLE
Lift:
[B]LSA[/B]
[I]LSA: 12605220 CAM CARD INFORMATION:
119 INTAKE CENTERLINE, 119 LOBE DISPLACEMENT ANGLE
1.70 ROCKER RATIO Lift: @ Cam @Valve EXHAUST: 0.283 0.480 = 12.2 mm INTAKE: 0.283 0.480 = 12.2 mm
EXHAUST: 79 BBDC 34 ATDC 293 INTAKE: 5 BTDC 86 ABDC 271
EXHAUST: 46 BBDC 10 BTDC 216 INTAKE: 21 ATDC 39 ABDC 198[/I]
[B]L92[/B]
[I]PART NUMBER 12612273 2007 L92 6.2L CAM AT NOMINAL TIMING:
115.5 LDA 116 INTAKE CENTERLINE ‘NOMINAL’ (99 AT PHASER PARK)
1.70 ROCKER RATIO Lift: @ Cam @Valve EXHAUST: 0.294 0.500 INTAKE: 0.294 0.500
EXHAUST: 69 BBDC 35 ATDC 284 INTAKE: 8 BTDC 90 ABDC 278
EXHAUST: 38 BBDC 9 BTDC 209 INTAKE: 18 ATDC 36 ABDC 198[/I]
*Duration measured at .050″ tappet lift.
Here's the link to original post by Matt Martin.[/I]
[URL]https://jankyshack.com/gm-ls-cam-specs/[/URL]
[I]Here a Video >
https://youtu.be/JJyAmihjnSs[/I]
Corvette LS1
Corvette LS6
Corvette LS6
Camaro/Firebird LS1
LR4 and LM7
LQ4
LQ9
Gen 4 LS:
Corvette LS2
Corvette LS3
09-13 12631811 ???
Corvette ZR1 LS9
Corvette LS7
LS7:
Lift:
[B]LSA[/B]
[B]L92[/B]
[I]Here a Video >
