ok, i'm trying to install a set of speedglo gauges in my truck. the problem is, i can't seem to find a wire to power them with. i would like to have one that is only hot when the ignition is on, however now i'm about ready to take whatever will do the job.
also, can anyone tell me how hard it will be to get the original gauge facing off. i havent taken a really close look at it yet, but if at all possible i would like to remove it instead of laying the new ones over it.
thanks
cyberfoe
Early Member
Check your fuse block for a pink wire #39, fuse #4 10 Amp. According to the wire diagram this wire is part of your interior lights. Hot with ignition on.
Early Member
Originally posted by Got-20z
i used the wire that powers the headlight switch [/B]
Headlight switch is Hot at all times.
